IS-XPT-2100 Serial Control via NetLinx Program
bbriles
I cannot make the XPT 2100 send a serial string out from a NetLinx master. I have the protocol loaded in the XPT 2100 and can send strings using the http://serialcommand.html?, I know I am talking with the player from the NetLinx master because I can control layouts. But I cannot make this work. So far the documentation I have found shows to send:
Send_String dvIPServer,"'UPDATE "amx:control:monitor:power" "Off"',13,10,13,10"
but this is not working.
Has anyone ever done this before?
Thanks.
Thanks.
http://<player ip>:25002/allprotocols.html
List all the protocols currently installed on the Player separated by semi colons
http://<player ip>:25002/protocol.html?<protocol name>
Activate a named protocol
The following examples show how you could control a typical display which supports a command to turn the screen on and a command to set the volume level:
http://<player ip>:25002/serialcommand.html?poweron
Send a command to turn the screen on
http://<player ip>:25002/serialcommand.html?volume=23
Send a command to set the volume to 23
http://<player ip>:25002/serialcommand.html?command=kf 00 10%0D
Send a command string to the display
http://<player ip>:25002/protocol.html?monitor2
You need to open a tcp/ip socket to the port 25002 and
