Nest HVAC and CO Module
 HARMAN_Lanussinio
HARMAN_Lanussinio
                    Hi AMX forumers,
What a good news, a NEST module available on the AMX website.
Does someone have already tested it and could provide feedback about it ?
Thanks to share.
Thanks to share.
Side note: the main feature is not avalaible (be able to setup temperature of thermostat......
Going to an app is a drag, especially if there are a few of them. The only app I ever will launch is Kaleidescape, by putting it on a button on my Kaleidescape page and I don't think it gets used very often to be honest. A lot of apps suck balls as well.
Which apps specifically? Some of the apps my clients have been using are certainly far from perfect, and don't even have all the features my little custom AMX module has. Most free apps are nowhere near perfect so it sounds like your customers are simply trying to get you to do work for free or something, or just like to complain. I hate the whole app thing, where you need a separate app for every little thing. I thought it was all supposed to be web services by now anyway with no client software. Remember that paradigm? Lol. Most of my clients get pissed if they have to leave the TPC app to do something which isn't very often so I'm not hearing this "I have a free app that's perfect..." thing.
That's true. What I've been finding is the the hardware costs are so large these days compared to the programming fees, that they really aren't much of a concern most times. Even a small theater or small home has tens of thousands in AV and automation hardware, so the programming costs are quite reasonable, considering you get things exactly how you want them more or less. Now that cheaper iPads/TPC are being used more often instead of expensive touch panels, clients really aren't too worried about the fees, as long as it works well and is easy to use, which is critical. No one wants to pay for stuff that doesn't work or is annoying to use.
The Nest module does work, but you have to do a bit of manual work to get it configured. The manual spells out some of the steps but it took a bit of guesswork to get it running. I forget the exact steps but I remember having to manually send a command with a PIN generated from the Nest website, and then issue a NESTCONFIG (or similar?, and maybe after a reboot?) to get the long IDs that can then be put into the module configuration section. Or something like that!
