How do i become a better programmer.
ajish.raju
I know a bit of Java,C, C++, VB6. In order to upgrade my skills, what all programming languages should i learn. What all certifications should i obtain. What all devices should i program. How do i get better.
It doesn't for me. Keep up or get out. That's the way of the world...
They have a long list if computer science topics:
http://ocw.mit.edu/courses/find-by-topic/#cat=engineering&subcat=computerscience
I found this one to be particularly interesting:
http://ocw.mit.edu/courses/electrical-engineering-and-computer-science/6-046j-introduction-to-algorithms-sma-5503-fall-2005/video-lectures/
Language wise, here's some thoughts from a few people much smarter (albeit with worse hair and glasses) than me:
Larry Wall
Bjarne Stroustrup
Don't get to bogged down on specific languages though. Every one will teach you a different way of thinking, try to extract what reusable knowledge and fundamentals you can from that. Languages come and go, the ways you can think of approaching a problem accumulate.
The number 1, most import thing you can do though is to build things. Think of something that interests you, a problem you want to solve or thing you want to create. It doesn't matter what it is. Build it. You'll be astounded at what you can learn by just diving in and doing something. As long as you have an internet connection chances are you'll be able to find a solution to any sub-problem you come across either through Google or StackOverflow StackOverflow. Aside from that, one you've familiar with a language keep an eye out for open source projects in it, preferably ones that will help with something you use or need. This will let you work with other people, workout how to work with different types of people and glean some of there knowledge while you're there.
Learning about searches (breadth first, depth first), sorting, graphs, hashes, and other structures will really help you since they are so general and are applicable in so many areas. I am writing a JSON parser at the moment, and doing it without the concepts I've learned would be a struggle. You'll notice that you will end up writing a lot less code that does a lot more.
