Problems learning a remote with IRIS - Cisco 8485DVB cable box
Hi guys,
Using the IRIS I am trying to read in the IR codes for a Cisco 8485DVB cable box to no avail! Every other remote I try can be read in, just this one I can't get learned by the IRIS! Tried almost everything, short press, long press, etc. I even set the Logitech Harmony Touch to this device and tried it with the IRIS but no luck at all.
Anyone by any chance has an IRL file for the Cisco 8485 or 8455 cable box? Any other hints what I might try?
Thanks very much!
Thanks very much!
The device IR receiver was on a different spot - it was absolutely not visible and also not properly marked. By detaching the IR flasher from the device, holding it a couple of inches away from the display and pressing buttons on the TP, I was able to locate the proper location!! Phew...
