DGX16 Dev 5002 doesn't come online after firmware update
in AMX Hardware
After upgrading DGX master(1.4.76) and switcher(2.0.4) firmwares,
Device 5002 doesn't come online when AMX Lan authentication is set.
Diag log
Diag log
[COLOR=#212121][FONT=Helvetica Neue][SIZE=13px] Line 1982 (16:04:00.085):: Closing connection to ::1 due to username/password authentication failure; Sys=2 Dev=5002 Line 1983 (16:04:00.085):: CICSPTCP Rx connection to ::1 (socket=110, idx=13)has been closed locally or by peer, byteRead=0, errno=0 Line 1984 (16:04:00.085):: CICSPTCP:Run() idx=13 exiting, m_bExitRun=2! Line 1985 (16:04:00.100):: CICSPTCP::ShutdownICSPTCPTasks(),bExitRun=2, iSocket=110 (idx=13), shutdownCnt=1 Line 1986 (16:04:00.100):: Closed Socket Connection socket=110 addr=::1 index=13 Line 1987 (16:04:00.100):: No session to clear for this connection Line 1988 (16:04:00.100):: CIPConnectionManager::ProcessICSPPacket msg destined for outside but no socket exists iIndex=13 wCommand=$FF00 wCommand+2=$0900 Line 1989 (16:04:00.100):: IcspTcpTransport.diconnect: closing socket Line 1990 (16:04:00.460):: Memory Available = 944332800 <98304> Line 1991 (16:04:02.600):: IcspDeviceStack.run() calling transport::Connect() Line 1992 (16:04:02.600):: IcspTcpTransport::urlConnect(localhost) Line 1993 (16:04:02.600):: Master accepted connection. Line 1994 (16:04:02.694):: Accepted connection:socket=110 addr=::1 port=45783 Line 1995 (16:04:02.694):: Memory Available = 944316416 <16384> Line 1996 (16:04:02.694):: CICSPDatabase::SetAccessToken: Line 1997 (16:04:03.600):: Closing connection to ::1 due to username/password authentication failure; Sys=2 Dev=5002 [/SIZE][/FONT][/COLOR]
Anyone
What does tech support say?
The process is as follows:
Remove all I/O cards ( if has audio injector/extractor card then leave in then leave these in as not hot swapable)
Reboot DGX
Wait for 5002 to come online (in online tree)
Replace all I/O Cards
Firmware update Switcher even if the latest and it will update the I/O Cards.
Like I said - might not be the same thing...
