HTML request
Hi, I have some issues getting this code to work. I am trying to get info as .XML, but I don't recieve anything. No Online or string events, I do get a onerror timeout event after some seconds. Opening a connection through telnet on port 80 and typing in the GET request, I get the information I want, so the request is correct, but it wont send it. I have tried forcing it by waiting x ammount of time but it cant send because the connection isn't opened. I have tried going with the www.yr.no IP as well. Any ideas?
The information and policy cna be found at http://om.yr.no/verdata/xml/spesifikasjon/ (in norwegian)
PROGRAM_NAME='dvYr'
  CHAR sYRBuffer[5000]
  INTEGER Test1, Test2, Test3, Test4
  CREATE_BUFFER dvYR, sYRBuffer
  BUTTON_EVENT[dvPanel,123]
      SEND_STRING 0,"'IP_CLIENT_OPEN(dvYR.port,www.yr.no,80,IP_TCP)'"
      IP_CLIENT_OPEN(dvYR.port,'www.yr.no',80,IP_TCP)
      SEND_STRING 0,"'Test1 = TRUE'"
      Test1 = TRUE
  BUTTON_EVENT[dvPanel,124]
      SEND_STRING 0,"'IP_CLIENT_CLOSE(dvYR.port)'"
  DATA_EVENT[dvYR]
    ONLINE:
      SEND_STRING 0,"'GET /sted/Norge/Akershus/Ski/Ski/varsel.xml HTTP/1.1',$0D,$0A,'HOST: www.yr.no',$0D,$0A,$0D,$0A"
      SEND_STRING dvYR,"'GET /sted/Norge/Akershus/Ski/Ski/varsel.xml HTTP/1.1',$0D,$0A,'HOST: www.yr.no',$0D,$0A,$0D,$0A"
      SEND_STRING 0,"'Test2 = TRUE'"
      Test2 = TRUE
    ONERROR:
      SEND_STRING 0,"'***TRACE - IP CONNECTION FAILURE***'"
      SWITCH(data.number)
        CASE 2:{SEND_STRING 0,"'Error Connecting',$0A,'2:General Failure(Out of Memory)'"}
        CASE 4:{SEND_STRING 0,"'Error Connecting',$0A,'4:Unknown host'"}
        CASE 6:{SEND_STRING 0,"'Error Connecting',$0A,'6:Connection refused'"}
        CASE 7:{SEND_STRING 0,"'Error Connecting',$0A,'7:Connection timed out'"}
        CASE 8:{SEND_STRING 0,"'Error Connecting',$0A,'8:Unknown connection error'"}
        CASE 9:{SEND_STRING 0,"'Error Connecting',$0A,'9:Already closed'"}
        CASE 14:{SEND_STRING 0,"'Error Connecting',$0A,'14:Local port already used'"}
        CASE 16:{SEND_STRING 0,"'Error Connecting',$0A,'16:Too many open sockets'"}
        CASE 17:{SEND_STRING 0,"'Error Connecting',$0A,'17:Local Port Not Open'"}
        DEFAULT:{SEND_STRING 0,"'Error Connecting',$0A,'17:Local Port Not Open'"}
    STRING:
      SEND_STRING 0,"'String received!'"
      SEND_STRING 0,"sYRBuffer"
      SELECT
        ACTIVE(FIND_STRING(sYRBuffer,'HTTP/1.1 200 OK',1)):
          STACK_VAR INTEGER nHeaderEnd
          STACK_VAR CHAR sHeader[300]
          STACK_VAR CHAR sBody[100]
          SEND_STRING 0,"'Test3 = TRUE'"
          Test3 = TRUE
          nHeaderEnd = FIND_STRING(sYRBuffer,"$0D,$0A,$0D,$0A",1)
          sHeader = GET_BUFFER_STRING(sYRBuffer,nHeaderEnd)
          GET_BUFFER_STRING(sYRBuffer,3)
          sBody = GET_BUFFER_STRING(sYRBuffer,LENGTH_ARRAY(sYRBuffer))
          SEND_COMMAND 0,"sHeader"
          SEND_COMMAND 0,"sBody"
          SEND_STRING 0,"'Test4 = TRUE'"
          Test4 = TRUE
    1) How is dvYr defined?
    2) Are the DNS settings for the AMX master set correctly?
  • DraugarDraugar Posts: 27
    This is on my home controller by the way.
    The DNS Entry 1 is set to 192.168.1.1, the same as my computer shown with IPCONFIG
      dvPanel        = 10001:1:0;    // Touch Panel MVP-5200i
      dvTP50PZ550     = 10001:3:0
      dvTPRPi        = 10001:4:0
      dvTPA300        = 10001:5:0
      dvYR            = 0:8:0;    // www.yr.no
      #INCLUDE 'dvRPi.axi'
      #INCLUDE 'dvA300.axi'
      #INCLUDE 'dvYr.axi'
    Solved!
    My issue were the Gateway IP, wich were set to 192.168.1.0, and not the correct 192.168.1.1. Thank you Joe for giving me something to tripple check! :D
    Glad you got it working...
