Is IR EDIT supported by Windows 10 ?
Is IR EDIT supported by Windows 10 ?Is IR EDIT supported by Windows 10 ?
Follow the order to install it on Windows 7 :IREditSystemFiles.exe >IREditSetup.exe>AMXIR.exe
AMX hasn't updated IRedit since 2006. I was suggesting that maybe you should check your .NET version, and install an old one if need be.
I was looking, found this thread and will share this as my solution that worked for me - http://workblog.pilin.name/2013/11/how-to-install-net-framework-11-on.html
Cameron
