DVX Relay control
I'm super confused.... I swear this was working last week and now it's failing.
Basically I'm using the relays to trigger an amp on and off... when the relay is closed the amp turns off...
So, as an example, I have this:
and then the off function-
If I telnet into the master I can run ON[dvDVXRelay,1] and OFF[dvDVXRelay,1] and that works fine and peachy... until my functions run- then I can't turn the relays on or off via telnet (and they don't toggle via my functions)... even more baffling to me is in the notifications window when I call the fnPowerDnLounge... i get this-
Line 7 (11:30:22):: Feedback:On [5001:21:2] - Channel 1
Line 8 (11:30:22):: Output Channel:On - From [5001:21:2] - Channel 1
...even though the relay doesn't change. Other functions (video switching) still work....
Any advice would be greatly appreciated... I'm completely baffled!
DEFINE_FUNCTION fnWatchBluRay()
SEND_STRING dv402BluRaySerial, "'PON',$0D"
SWITCH(nZoneSelect)
//lounge
CASE 2:
PULSE[dv402TV,POWER_ON]
SEND_LEVEL dv402SwitcherOut2,1,30 //volume to 30
SEND_COMMAND dv402Switcher, "'CI4O2'" //input 4 to output 2
SEND_COMMAND dv402Switcher, "'CI4O1'" //mirrored to conf
nLoungePowerOn = 1
OFF[dvDVXRelay,1]
//deck
CASE 3:
SEND_LEVEL dv402SwitcherOut3,1,30 //volume to 30
SEND_COMMAND dv402Switcher, "'CI4O3'" //input 4 to output 3
nDeckPowerOn = 1
OFF[dvDVXRelay,2]
DEFINE_FUNCTION fnPowerDnLounge()
IF (nDeckPowerOn = 1)
SEND_COMMAND dvTP_iPad,"'PAGE-Main-Deck'"
nZoneSelect = 3
ELSE
SEND_COMMAND dvTP_iPad,"'PAGE-Logo'"
nZoneSelect = 2
SEND_COMMAND dv402Switcher, "'CI0O2'"
nLoungePowerOn = 0
ON[dvDVXRelay,1]
The define device is:
Danny
