The "more than one thing" from the other side, too...
I'm actually pretty happy with my current project, except for the daunting task of completing RMS integration. I've got one or two controllers running 20 classrooms (only 6 of which are online so far), and I'm struggling to be able to get stuff like source selection tracking working for each room under those circumstances. Now I've realized that my redundant controller strategy also might create that problem from the other side: I probably can't get RMS to allow me to have two different controllers alternately report on a single room.
Any tips / tricks / suggestions? Anyone ever face or try this before? It seems like an Eric Medley is about the only answer.
Once it has done the hello - you are perfectly okay to move that master to an existing "Location" other than the one it currently resides. Similarly, you can manually create your own location and put whatever you want there.
On a similar note: things like control methods (stuff like "Power On A Room" or "Select Source X"
) are again nothing more than commands that get sent back and forth to/from a master. If you watch your vdvRMS device in notfiations, you'll see the control method command come in. You can simply parse for this command and then write code on the master of location X and have it do whatever you want.
To see the actual commands that are being sent between the RMS server and the SDK look at the tail end of your manual. It's much easier in my mind to just speak directly to RMS than to try to get my head around the SDK and now it does things. It's honestly not as complicated as the SDK seems to make it.
I've attached an example of the amended source usage file I'm intending on using. In essence create a NX Virtual Dev for each room.
Aside from that I second what Eric is saying above. RMS Enterprise has allowed that extra layer as it were to enable you to drag and drop assets around regardless of the gateway they are using.
the order of things is:
a new master comes online for the first time in RMS. It will then ask you to assign that master (gateway) a Location; either currently in the database or a new one.
Once assigned to a location - all the devices (assets - NXBs/Touch Panels/Axlink stuff/ etc...) will then be automatically assigned to whatever location it's parent Gateway is.
You then need to manually create new "Locations" in RMS that represent the other rooms you want stuff to live in.
Then go into the Asset's properties and move it to the new location.
Wash-Rinse-Repeat.
One last little nugget of information - there is a help command in the newer versions of the SDK. Rather than just observing the chatter between your NetLinx program and the RMS Client, you can issue a command like the following to get quick access to the available APIs.
send_command vdvRMS, '?-<help-search-filter>'
Thanks for the info. Yes, this is a system where a central controller is running 21 rooms, and we're trying to build in some redundancy in the event of a controller failure. The client had asked for it anyway, and I've already had 2 brand new NX-3200 controllers fail in this installation while we were building it.
Overall I'm pretty happy with the controller redundancy. Both controllers run the exact same code and can handle all 21 rooms. Half the rooms normally run on one controller, the other half on the other. If I need to move a room from one controller to another, all I have to do is change a DNS alias (which controller the panel, SDX, and DX-RX point to), and reboot the panel. NOTE: If AMX equipment honored DNS TTL, I wouldn't even need to reboot the devices, but none of them honor DNS TTL values; they need rebooted or power cycled to refresh DNS cache. So: change DNS, reboot the panel.
On panel offline, it closes all outbound IP connections (projector, rear display, and audio control). On Panel online event, it opens up all outbound IP connections, and checks to see if the SDX and DX-RX are online. If not, it telnets into them and force reboots them. When a rebooted SDX or DX-RX comes back up, it will get the new DNS and connect to the new controller.
In practice, the SDX and DX-RX are incredibly inconsistent about the time they take to connect to a controller. It can be anywhere from a few seconds, to a couple of minutes! I'm seriously thinking about just using Telnet connections to control the devices because of the inconsistency of reconnect time. But for now, even with the sketchy device connection times, I can recover from a controller failure and move 10 or 11 rooms to another controller and have the entire system and a dozen rooms up and running again in about 5 minutes. I think that's pretty damned good as far as disaster recovery from a controller failure.
YES. Reference the "Pod" and "Flipped" classroom phenomenon. We frequently have rooms with multiple (3-10) displays. We need to track multiple device states, and multiple source selections for each device, in a single room. And yes the other way too, multiple controllers for a single logical system, that controls 21 rooms, all with more than one output device in each room.
This is not an exception. This is becoming the norm.
