XTP?use of remote RS-232 port ?
Hi
I'd like to know if someone has already used the serial port available on the remote XTP box that goes with XTP matrix from Extron ? It looks like you can send/receive strings of these remote ports just by connecting on a specific IP port on the matrix !
Does it work ? someone tested ?
Vinc
Vinc
It works as you've described in your post and you can find the ports you need by connecting to the XTP switcher using the configuration software (or even the web interface possibly). The ports are editable as well which is nice.
