Biamp Tesira heads-up.
Just a quick heads-up for anyone working wit a Biamp Tesira. As of June 2016 the new firmware comes with a new feature. By default the Telnet IP port is turned off. You will need to go into the settings on the Tesira (via the software) and make sure to turn it on. Otherwise you'll spend an hour trying to figure out why your once working module is struggling... Up to this point, that port was open by default. After speaking with an engineer at Biamp, I would also keep an eye out for the possibility of the control port moving over to the SSH port.
Well, security and more importantly the various governing bodies/accreditations are finding that telnet is just to unsecured and vulnerable. I's harder to get into secure spaces with it. Since SSH is essentially the same basic communication type but adds encryption and mandatory login credentials, it's an obvious way to go. I can say I've been in two spaces where the Network Admin was blocking port 23. In both casSe rs232 was the solution. But m sure ll hit that wall at some point.
But thanks for the heads-up - I have a lot of Biamp products, Tesira Forte's and Nexias, being controlled over IP.
LOL! Funny, in a very sad way.
