Lights control
Hi,
This should be simple, but somehow I just can't get it work right...
In order to control a Helvar Digidim dimmer controller you send four hexadecimal numbers to set the level: 03, 51, 80, dd, in which the last is dd = DALI level of
00 through FE. Eg. SEND_STRING dali, "$03,$51,$80,$1E". I'd need +/- buttons and a level indication bar to the touch panel.
Would somebody help pls.
Best regards,
Markku
AV-systems
Best regards,
Markku
AV-systems
