Metreau Communicator Snapshop
Does anyone know the URL for a snapshot off the webcam, or the FTP username and password? AMX doesn't know....
http://www.amxforums.com/forum/technical-forum/amx-hardware/7473-met-ecom-live-snapshot
Met-Ecom firmware is v1.01.22 and the code is running in an NI-700 v3.50.430.
Yes I used the same code, but am getting the truncated image. I am using 1.01.20 so I can upgrade the FW and see if that makes a difference. Any chance the delimiter could be getting in the image file?
Dimensions 320x240
Width 320 pixels
Height 240 pixels
Horizontal resolution 96 dpi
Vertical resolution 96 dpi
Bit depth 24
The spec for the Met-Ecom is QVGA 320 x 240 so I'm getting the entire frame and the file looks normal to me.
I get the same specs. I've uploaded the latest FW but haven't been able to test it yet. Here is the image I was getting with the bottom 1/4 not visible. In windows viewer its a gray area with dots. Once uploaded to Photobucket it is just cropped as seen here.
Attached is a fresh snapshot. Everything that appears on the web interface shows up in the snapshot. All corners filled in properly.
How is your lighting? How about network? Just guessing at this point.
