LG TV Tile Mode
Hi,
Does anyone had controlled the Tile mode operation of LG TV 42SHdB7,,,,
I have 2x2 setup and I want to control 2 modes of operation,, 1 full screen and 1x1 ..
Does anyone had success on it..
  • NZRobNZRob Posts: 70
    From a manual:
    39. Tile Mode (Command: d d)
    To set a Tile Mode and Tile Column/ Row values.
    Transmission
    [d][d][ ][Set ID][ ][Data][Cr]
    Data 00 to FF: 1st byte - Tile Row
    2nd byte - Tile Column
    *00, 01, 10, 11 means Tile Mode Off.
    Acknowledgement
    [d][ ][Set ID][ ][OK/NG][Data][x]
    ** It may not be supported depending on the model.
    for a 2x2 setup use 'dd 0 22' to turn on and 'dd 0 00' to turn off.
    ID is 0 for all displays
  • thanks rob
