NEC NP-PX803UL IP Control
Hey guys,
Does anyone have any experience controlling the NEC NP-PX803UL projector via IP? The Duet module yields EXTREMELY inconsistent control and it looks like I'll have to roll my own module. Only problem there is the user manual is unclear on how to control it IP...no mention of port to use, method, etc. And still waiting on info from NEC.
Any experience you might have or guidance here would be very helpful. I'm in the last week of a project and this is the final hurdle to overcome.
Many thanks!!!!
Many thanks!!!!
I did end up getting a "working" module going for it. The projector was not terribly cooperative over IP so I had to put in a good deal of workarounds in the module to get it to behave. Mostly issues with not responding to anything but power on when off (which killed my usual heartbeat and initialization logic) and only sometimes allowing new connections, sometimes not. I can't say that I'm 100% confident in control of it due to the hardware issues themselves but what I ended up with is pretty close and seems to be pretty stable at the site.
I'd be happy to share with you what I have if you need it.
Which AMX device are you referring to? EXB-COM2 or MP1? could you explain a bit more?
Richard
Our experience was with the COM2, but the MP1 appears to be the same generation technology.
Specifically, the unit defaults/boots to 9600 baud, 8,n,1. If it is set by your program to any other setting on initialization, as you do the netlinx ports, it only holds until the COM2 (and probably MP1) loses power or reboots otherwise. Then it's at 9600 again. NO BATTERY BACKUP for settings. The MP1 might have a battery to keep the IR alive, but I can't tell by the specs.
When we discovered this and reported it as a problem, AMX acted like we were crazy to think settings should tolerate reboots. I reminded them that -every-one- of the other many IP/Serial adapters from other vendors hold settings through power issues... silence...
We were forced to programmatically re-init the port at key times just to be sure it would work. However, re-init can cause glitches in some connected Serial devices. So... good luck. We're pretty happy with the DIGI-ONE SP.
Although I does seem easy enough to just add a 'set baud' command in the 'online' event of the device, doesn't that work? That's basically the way every onboard com port gets it baud rate, isn't it?
This is my method and have hardly had an issue (except for when I had a MP1 that a fellow programmer set to RS485 in code and caused it to lock up!)
