Document Camera Feedback
TUTech
I'm working with document camera feedback to show the power status in case someone turns it on or off without using the control panel. The problem is that the response has a space in it.
Can I put a space in find_string(data.text," ") OR can I put an ELSE statement in STRING / DATA_EVENT??
When power is on I get $B0a$80$02$00$BF
When power is off I get $B0a$80 $00$BF
This works if it is turned on from the camera.
DATA_EVENT [dvDocCam]
STRING:
IF(LENGTH_STRING(data.text))
SELECT
ACTIVE (FIND_STRING(data.text,"$80,$02",1)):
nDocPwr = DPWRON
Can I put a space in there data.text,"$80, ",1)):
I tried to put an ELSE statement in there (IF it's not ON then it must be OFF) but that didn't work.
STRING:
SELECT
nDocPwr = DPWRON
Power on response : $B0$61$80$02$00$BF
Power off response : $B0$61$80$20$00$BF
Richard
Sorry for the double post!
David
so your conditional would look like
FIND_STRING (data.text,' ',1)
This is what I used and it works perfect!
STRING:
SELECT
nDocPwr = DPWRON
ACTIVE (FIND_STRING(data.text,"$80,$20",1)):
nDocPwr = DPWROFF
That's good! I'm glad it works. And just for future reference. "$20" and ' ' ('<space bar>') are the same thing.
I found another part of the program where I got '@' as feedback. I replaced it with the correct hex value and it worked.
Thanks again.
