Q-SYS Core 110F
Hey everybody,
Seeing if anyone has has to work with a Q-SYS Core yet. If so how did it go? Was the protocol pretty straight forward?
DWT
DWT
FYI - the serial port is not intended for external control, but I have been a situation where I needed to use it. I had to write a custom module on the Q-Sys Side to tie custom controls to that port.
Agreed. Absolutely one of the best features.
The POTS line is flakey. We had to use a Patton VoIP Gateway because the POTS on the Core wouldn't do DTMF. Other than that, works and sounds great.
