DynDns Update module?
Does anyone have this working still? I haven't used this in a long time since the routers I supply usually handles this but now on one job the owner changed my router to one that doesn't provide the dyndns update so now I putting the module in but it doesn't seem to be working. I'm not getting anything back but it does trigger the string event handler. I tried switching from port 80 to 8245 the secondary port for the HTTP socket that dyndns uses but the exact same thing. I connect, send my get header but nothing is returned or shows in my buffer but the string event triggers.
It could be I'm blocked now since I did read that frequent requests will result in blockage since they don't want see frequent updates where the IP is the same. I would hope if the blocked the client IP they would respond with a blocked notice.
Vining; another thing you might want to check is your HTML header information. I don't know if you're like me - but I don't update that hardly at all. but, I've had to do so in recent projects where RSS feeds end up blocking chatty things with seeming older browser identifications. When I updated the GET message to something I just scraped off my current IE or Chrome browser all seems well again. Just a thought you might look at.
E
Oh! Imagine that! The API doesn't match reality. It'll never happen.
First they sent me this URL command method which is different form their online URL method. Not what I wanted but it gave me something to work with and eventually used this to modify the RAW command format. A bit of a pain since sometimes servers are blocking and sometimes they're not and if you send them garbage a couple of times they'll block you and you have no way of knowing that's the problem and not you code syntax. So using wireshark I was able to use the GET format for the above URL command that send user:pass in the URL to the RAW format that uses the basic encrypted base 64 in the header and eventually it works.
I really didn't need to bother with this but I haven't played with code in a while and it is a tease that junkies find irresistible.
This is what I sent to DYN and hopefully they'll update their web page, yeah right, but the last version in the quote section below seems to work properly at present.
