Yamaha RX-V781 ip control NX-2200
Metso
We should control Yamaha RX-V781 receiver via ip. (power, volume, input). We have done this before successfully with a RX-A2010, but that concept (YMCA) does not work. There is no longer a rs-232 option left in this model. Can anybody help?
That should not not make a difference. Do you have the protocol document?
Yamaha is connected to the same switch as NX-2200 and touch panel. All have static ip addresses. This worked previously for the RX-A2010.
// NETLINX NX-2200, 192.168.0.50
AMPL = 0:1:1 // IP: Yamaha RX-V781; 192.168.0.70:50000
CREATE_BUFFER AMPL,cBuffer;
DATA_EVENT[AMPL]
ONLINE:
CANCEL_WAIT 'CONNECT'
bConnected = TRUE;
CANCEL_WAIT 'TRYING TO CONNECT'
bBusyConnecting = FALSE;
OFFLINE:
bConnected = FALSE;
ONERROR:
bConnected = FALSE;
STRING:
// PARSE XML - using cBuffer
DEFINE_PROGRAM
WAIT 100 'CONNECT'
IF (bConnected == FALSE && bBusyConnecting != TRUE)
bBusyConnecting = TRUE;
IP_CLIENT_OPEN(AMPL.PORT,'192.168.0.70',50000,IP_TCP);
WAIT 100 'TRYING TO CONNECT'
PUSH[TP,101]
SEND_STRING AMPL,"'@MAIN:INP=AV1',13,10"
VOLUMELEVEL=60 //=-20.0 DB
CALL'SET_VOL_LEVEL'
Remove the whole named wait thing, especially from mainline. If you are going to keep it, at least get it out of mainline and use a while or something. What you should really do is use a timeline at a specified time to attempt to reconnect. Either try to connect once at start or start the timeline, using the ONLINE, OFFLINE, and ONERROR appropriately.
- There is a tech note commenting on this, but I can't seem to find it.
Move this:
[code/]
WAIT 100 'CONNECT'
IP_CLIENT_OPEN(AMPL.PORT,'192.168.0.70',50000,IP_T CP);
[/code]
into a TIMELINE_EVENT
and move this:
[code/]
PUSH[TP,101]
CALL'SET_VOL_LEVEL'
[/code]
into a BUTTON_EVENT
There was a mistake in our previous post: Device id should be Ampl= 0:3:1.
We tried to modify the program as Jim told but that did not help.
With a browser the receiver controls ok and Putty shows the traffic, but NX-2200 seems to send nothing.
Also got an old NI-3100 and found out that our original program controls just fine the RX-V781, so there must be something different with the NX and NI controllers...
If thats true then I would hedge my bet that its because of how your using the DEFINE_PROGRAM. Like we stated earlier that should be removed and place in an recurring timeline based on the feedback of the IP connection (ONLINE, ONERROR, OFFLINE).
Thanks for the code post. My code, while written completely differently, achieves almost the exact same thing. The only 'extra' thing I've got going in my code is that it will try reconnecting 10 times relatively quickly (~5 sec), then bumps up the wait before retry to 15 minutes, then eventually bumps that up to 30 minutes if it still cant connect. Generally, if it doesn't reconnect right away, there's a network problem that may take some time to resolve. My experience is that I pound on unsuccessful IPConnect requests to hard for too long, it eventually locks up the controller's IP port and requires a reboot to recover.
