Enova DGX 16 ENC. Firmware recovery
patriot_stv
in AMX Hardware
Updated the firmware on the amx enova DGX 16 ENC. First, we installed NI Master firmware v.4.2.395, then Firmware Upgrade kit v.2.0.4. After the second update, the connection to 5002 in netlinx disappeared and enova turned on, but did not commute the video. Can I repair the firmware myself?
P.S.
Today there was a miracle.
I came to work, and the matrix works! ))))
I do not know how this is possible. Nothing was done with her. They just did not turn it off yesterday when they went home.
To follow the upgrade status
It should be mentioned that you should load that page up on a separate browser session before starting the upgrade process. Trying to access after beginning the upgrade may not be possible with older firmware versions.
