Hitachi projector lamp hours
MLaletas
This could be considered lazy, although I did try to research the topic a good bit. The manual is super vague for the expected response back from the hitachi projector. Wondering if anyone knows what the expected response is for the lamp hour query? I cant tell which of the two bytes determine what... Maybe im stupid?
here is the excerpt
RS-232C Communication (continued)
3. Response code / Error code ("h" shows hexadecimal)
(1) ACK reply : 06h
When the projector receives the Set, Increment, Decrement or Execute
command correctly, the projector changes the setting data for the specified
item by [Type], and it returns the code.
(2) NAK reply : 15h
When the projector cannot understand the received command, the projector
returns the error code.
In such a case, check the sending code and send the same command again.
(3) Error reply : 1Ch + 0000h
When the projector cannot execute the received command for any reasons,
the projector returns the error code.
In such a case, check the sending code and the setting status of the projector.
(4) Data reply : 1Dh + xxxxh
When the projector receives the GET command correctly, the projector returns
the responce code and 2 bytes of data.
NOTE ? For connecting the projector to your devices, please read the
manual for each devices, and connect them correctly with suitable cables.
? Operation cannot be guaranteed when the projector receives an undefined
command or data.
? Provide an interval of at least 40ms between the response code and any other
code.
? The projector outputs test data when the power supply is switched ON, and
when the lamp is lit. Ignore this data.
? Commands are not accepted during warm-up.
? When the data length is greater than indicated by the data length code, the
projector ignore the excess data code. Conversely when the data length is
shorter than indicated by the data length code, the projector returns the error
lets say the lamp hours were at 508
bear in mind a byte's max value is 255 (0xFF).
So, to split the value up so it works:
GSB =$01. ( $1 X $100)
LSB = $FC
so to do,the math
lamp hours = ( GSB X $100) + LSB
If it uses this method, t would be easy to figure out which byte was the LSB and GSB by knowing what the projector said it's hours were in the on screen display and the two hex values it returned.
also, the AMX module for the Hitachi does work - just sayin...
Also I'm ignoring that last part
REMOVE_STRING(data.text,"$1D", 1)
Temp=MID_STRING(data.text,1,1)
PROJ_LAMP = (Temp[1])
Here again - with the usual disclaimers about not having the protocol at hand...
If our assumption that they are doing the usual LSB/MSB method of getting past the $FF limit of integers with single bytes I would guess the format of the message is
$1D = command/response ID where $1D means 'here's my lamp hours'
$01 = LSB
$00 = MSB
So the hex value fo the lamp hours is
$0001
When the lamp hours roll pas 255 you will probably see the 2nd byte turn to a $01.
Back in olden dayes of yore it was quite common for the MSB to be the last byte.
