MVP8400 Roaming
troberts
Has anyone used an MVP8400 to roam throughout a building and have it jump from access point to access point? I am having a problem doing this. The 8400 does not look for a new access point until the signal drops to fair....however. The 8400 does not seem to work properly with a signal of good. It is only working at very good.
At a signal strength of good I loose feedback and my panel goes off line. I am using the new firmware in the panel and the new firmware in the WAP200G. Has anyone seen this problem or can anyone help me.
Tim Roberts
Tim Roberts
Unfortunately, 802.11x does not work that way. A wireless device will not hop from access point to access point based on signal strength. One a device is associated with an access point it stays associated until the device drops out of range completely. The only way I know of to have your device associate with a closer access point is to reboot it in which case it will grab the first access point it finds which should be the closest one to it at the time.
Regarding the signal strength meters you are watching on the panel I?m not sure how often they are actually updated. I?ve had the same experience of having the meter read as good yet I still have problems transferring files to the MVP-8400 or it works sporadically. Are there any cordless phones in the area? Those can sometimes mess up your connection.
Cheers,
Joe
I do have the latest firmware in all my devices, but the biggest problem is, is that the panel goes offline even though the signal strength displays as good. There are no cordless phones and I am operating on channel 11. Anyone else care to help?
I haven't tried using the WAP's in repeater mode so I can't comment on that.
As has been said, multiple WAP's need to be on non-overlapping channels (ony 1, 6, and 11 don't overlap if you need more than two). They should, however, have the same SSID. I think, however, that repeater mode may be a better option for roaming panels. If I understand it correctly, the fact that you have switched WAP coonections is entirely transparent then to the panel.
I made the mistake on a project and going cheap by providing WAP's that I picked up at a local computer store, and I regret it to the point that I think I am going to rip them all out and put in the AMX WAP at no cost. A non-enterprise WAP simply is not as fast nor robust as the AMX WAP, and in the end will save you in hair-tearing and site time for the extra cost.
Why would repeater mode be a better option? My understanding is that repeater mode is used for areas where you can?t get a Cat5 connection to the WAP. I think you?re always better off plugging a WAP directly into the network vs. repeating to another WAP wirelessly.
As I mentioned before I also don?t think you can hop from WAP to WAP without going offline from the currently connected WAP first. For example, if I?m associated (connected) to WAP A and I walk over and stand right next to WAP B, which is 50? away from WAP A, my wireless device will still be connected to WAP A. Once I get out of range from WAP A then my device can associate to a closer WAP but not without going offline first. It is indeed transparent however the panel is still going offline. At least that?s the way I understand the technology. If I?m wrong I hope someone will set me straight.
Cheers,
Joe
That's certainly the way the panels behaved originally but I believe in the new firmware they've tweaked it so it doesn't have to loose the signal completely before switching. I think if the signal drops below a certain point it goes through it's routine to find the strongest signal. In any case it works tonnes better then it used to.
WLAN AP from time to time will broadcast beacon which provide information of the AP itself like SSID. Client devices have the capability to listen to all these beacons. Smarter devices can compare radio signal from all related beacons (apprently AP with the same SSID) and select to associate with the AP with the strongest radio signal.
In order not to switch too frequently between APs, wireless device may set a signal threshold (this level must be higher that the level that the client will drop the connection) to switch to an AP with better signal during roaming.
Cheers,
Charles
I set up a test in my office and had an 8400 jump from access point to access point using different channels and same SSID without a problem, but the panel did go offline from an NI3000 occassionally. It would also jump from no signal to good signal occassionally...without physically moving the panel. Does anyone know exactly how, when, and how quickly the 8400 will look for and/or link to a better signalled AMX access point?
Just a thought on the no signal to good signal jump.... are there any cordless phones in the vicinity? or have you checked for any other sources of interferance? Possibly someone else running a wireless network on the same channels? At our office, we had similar problems and as soon as we got rid of our Panasonic wireless phone system, everything cleared up. Ohh, also.... some of the cheaper access points on the market (Linksys for sure) have problems when there is more than 1 AP on the network and within range of each other.
Current config:
4 MVP8400s, 3 WEP200G, NI 3000 all with the most up to date firmware, all same WEP key, all same SSID, all different channels, all different static IP addresses. No other wireless devices (phones other access points or routers) on site. Did a set ethernet mode 10 half to NetLinx master.
Here is the problem
While connected to access point "A" at a level of "good" the panel goes offline from the master and even though there is better and closer access point "B" the 8400 does not connect to that access point until it drops to a fair or poor level on the panel. Basically the range of good is not good.
If the panel would jump to a better signal at a level of good my problems would be gone.
Any other ideas or similar problems or am I the only one?
According to AMX if you put an access point into repeater mode this problem goes away. Keep in mind you cannot have a repeater jumping off of another repeater.
