IP Control disconnects with SVSi 1xxx receivers
                                  in AMX Hardware
                    About a month into my first SVSi installation, my controller is occasionally losing connection to the receivers, and won't re-connect. I still need to double-check my error recovery code, but... anyone else have trouble keeping IP control connections to SVSi 1xxx series receivers open? Should I ditch keeping connections open, and only open for commands, then close?
yep, If you log into the SVSi's web page, you'll see a tab for Netlinx. You go there and can give it a device ID and point it tow the master you want. (It's just like any other AMX IP Device)
There are some basic commands you can do with simple Netlinx commands (like source select, etc...) but, there is no feedback on this stuff. It's essentially like IR control. You might need to do both.
But, activating the Netlinx connection does seem to keep things alive better.
E
