MVP8400 cannot get into the setup menu
in AMX Hardware
Dear All,
I have an older MVP8400 which has been disconnected from the local network due to an SSID change. I need to configure the new SSID but I cannot get into the panel setup with no way. Neither by holding the external buttons nor by holding on the center of the overlay while the panel boots up.
Is there another way to get into the setup ? Can I factory set the panel maybe by removing the CF card ?
George
George
Of course if I keep holding the screen, it does not even get into calibration mode. Nevertheless, it loads the UI file properly.
To be honest , there are times that when I'm pressing anywhere on screen - just to change pages - it seems as it is doing nothing like when the calibration has been lost. So that maybe the problem when I'm holding on center. I might not press on center eventually.
But how can I get into the calibration page since none of the known ways are working ?
Perhaps it's just time to let go.
SEND_COMMAND Panel,"'SETUP'"
