Has anyone had success with geofencing triggers?
imsocoimsoco Junior MemberPosts: 46
There are several apps that will allow triggers when a cell phone enters a geographical area. Lutron even uses it. Is there something we can use as an app that would work with AMX?
  • trobertstroberts Member Posts: 226
    Not the most secure way, since you need to port forward your router to receive the data, but you can use IFTTT and a webhook to trigger an HTTP post event to your processor. There are tons of things you can do with IFTTT
  • imsocoimsoco Junior Member Posts: 46
    Thanks for the info; I'll check it out.
    So you have used this and it proofed reliable as a trigger?
    imsoco wrote: »
    IMO anything that is internet based and in the world of IOT is never reliable enough to sell, but can be mentioned as a "bonus" feature, with the understanding one day it may stop working. If its for your own house, yes it is reliable enough and accurate to around 1/4 mile of your given location.
