Biamp ATC Tesira support in RPM
I got into a jam where my client switched out the AudiaFlex with a Tesira and i cant make the RPM project control the unit. i tried to make the Tesira DSP instance tags match the Audiaflex config but it just spits back errors. I have not spent the time to compare the Audia protocol to the Tesira but im shure it is just syntax in the code.
Can you provide a work around or an ETA when Biamp Tesira will be supported in RPM. I don't want to have to program this entire system from scratch as the job was not sold with that level of programming.
