Newbie Question
I have an existing G4 TPD file- how difficult would it be to alter it to an existing AMX Aqua Lens TPD file - would I have to change page by page or is there a way of importing the template
The only way this can be done automatically is between G4 PanelBuilder projects. For instance, if you have a PB4 project that uses the Graphically Sound template and decide you would rather use the Aqua Lens template, simply choose 'File->New From File' (or 'Start from existing project' from the Tasks Pane), select the existing PB4 project, and then select the new template to use.
I hope this answers your question and points you in the right direction.
Ive been playing around with it
