Configure Web User Interface Device
Hi,
I am using Televic Voting device.,its work in web Server .. This device having separate Window Screen ., I want to display that Device screen in my touch panel .,How can i make an code using button event .
Do you have a G5 panel? If so, you can launch a browser window via netlinx.
sorry, Am using G4 Panel., and its not a browser . The device its working on Http . I want to send an ' http:// IP_Address/Cocon/Connect ' to that device and wants to Display that device screen in my MST-1001 Touch panel. . Please Provide the Programming syntax
For a Roku but shows minimum requirement for building http 1.1. Roku implements GET and POST modes.
define_function sendRokuHttp(char iMode[20], char iCmd[50]) { stack_var char iPacket[500]; // Minimum HTTP 1.1 Requirement iPacket = "iMode,' ',iCmd,' HTTP/1.1',$0D,$0A, 'Host: ',uRokuIpConnection.address,':',itoa(uRokuIpConnection.port),$0D,$0A, $0D,$0A";// HTTP terminates with the empty line amx_log(AMX_INFO,"'sendRokuHttp(',iMode,',',iCmd,')'"); if(uRokuIpConnection.isConnected == TRUE) { amx_log(AMX_INFO,"'send_string dvIP_ROKU,',iPacket"); send_string dvIP_ROKU,iPacket; } else { sRokuIpQueue = "sRokuIpQueue,iPacket"; ip_client_open(dvIP_ROKU.PORT, uRokuIpConnection.address, uRokuIpConnection.port, uRokuIpConnection.mode); } } data_event[dvIP_ROKU] { online: { uRokuIpConnection.isConnected = TRUE; // Empty the Queue while(find_string(sRokuIpQueue, "$0D,$0A,$0D,$0A", 1)) // Standard HTTP terminator { stack_var char iMessage[500]; iMessage = remove_string(sRokuIpQueue, "$0D,$0A,$0D,$0A", 1); amx_log(AMX_INFO,"'send_string dvIP_ROKU,',iMessage"); send_string data.device,iMessage; } } } timeline_event[TL_ROKU_CONNECT] { sendRokuHttp('GET', '/query/active-app'); } button_event[dvTP_1_ROKU, BTN_MEDIADB_LIST] // BTN_MEDIADB_LIST from G4API { push: { stack_var integer iBtn iBtn = get_last(BTN_MEDIADB_LIST); sendRokuHttp('POST', "'/launch/',sRokuAppList[iBtn]" ); sActiveApp = sRokuAppList[iBtn]; // Fake feedback } }
