Looking for Ideas for Video Wall Programming
[Deleted User]
Hello all, I am new here so let me start off saying thank you, I think this forum will be a great way to make all of us(especially me) better programmers.
I am looking for ideas on a user friendly way to control a video wall with three displays. Sources will be 1 HDTV sat, 3 standard sats, a Escient music server, DVD, VCR, and Cable.
I am trying to come up with an intuitive(sp?) way to select sources for the displays, switch (Flip) sources w/audio to and from the main display, etc.
The displays are a 61" Plasma and 2 21" LCD's. I am using an AMX AS-16 for switching audio and AMX PLH-VS8's for Video. Also a MVP-7500 for control.
Thanks in advance for any help you can give! I am looking forward to hearing any ideas.
Mike
Mike
I started this yesterday but got called away to help remove a client head from his @#!. Myself I would maybe use a Matrix switcher for the routing of the video/audio signals for the standard video and a DA for the HDTV. This way there is only two input selections required on the displays.( less cabling to them also) Extron makesa 8x4 that sounds like it would just right with the amount of infomation that you have give. What type of "flash" are you looking for?
I am good on the hardware, I designed it exactly as you said, Matix for the standard video and a DA for the HDTV.
I need ideas for the user interface, I am having a hard time figuring a way to make it user friendly. I would like to do it with as few button pushes as possible but the user needs to be able to select source for all three TV's, select control for any source, and be able to swap video between displays. It seems like too many options to be "easy".
I know there is a slick way to handle this functionality. Every idea I have had so far though requires allot of pushing buttons. Just looking to see how better programmers than me did it, looking for inspiration.
Mike
Depending on what your client considers alot of buttons you could get away with 11-12 buttons to handle all the switching. Let me look around my office for a design I made up awhile ago.
Here is a sample design I did some time ago. I changed the buttons to match your job info. Best of luck.
I really appreciate the time you spent helping me out!
Thanks again,
Mike
It may be more intuitive for the user if you displayed a graphic representation of the video wall, selecting a single cube would then popup a popup with the sources available to route to it. With a couple of titles on the popup and page it would be very easy to use. If you are doing more advanced configurations (using mulitple cubes for a single source you could make smaller icons below the main screen for those special "modes". I used a similar technique on video wall job and the client seemed quite pleased, it was for a retail store and the turnover in was quite high, training would be an issue so it needed to be very easy to operate. If this seems confusing I can build a quick mockup for you.
Have attached a shot that I use for a videowall. It requires a bit more supporting logic (Netlinx code) behind, but the customer does not need to figure out which SAT he should try in order to get SkyNews, for example.
I am stronly in favor of action-centric design, where technical implementation is hidden from the customer. By the way, can anyone share their view on the design subjects?
BTW : your page seemed very clean and logical to follow.
Can you recommend some reading on visual interface design? I am going to get into "Usability Engineering" by Jakob Nielsen and "The Design of Everyday Things" by Donald A. Norman.
Just wondering, may be someone has already found something worse to read and use?
