Tp Design
Hi everyone
I'm busy designing a panel for my house using TP design(pre ver 3.0) and I am not having any luck with the icon-feedback function. I've followed the 'help' menu to a T but still can not get the icon feedback function to work. Does anyone remember how to do this?
First of all I would suggest you to go to TP 3.16 - wich is the most recent one (awailable on AMX website). Then, if I'm getting you correctly - you trying to assign different icons for on an off states? Create button, right click on it, select 'Icon' from pop-up menu. On the right of the window that openes you should see icons selected for each state - just click on the state and select icon from the list on the left. It should appear in the state box. Just keep in mind, that you should have all necessary icons imported into the program ('Panel' in the main menu, then choose "Icons' - in the window click on 'Import'). Good luck, D.
It's gotta be REALLY old to not support an upgrade.
