IR edit
 Thomas Hayes
Thomas Hayes
                    Hi everyone,
Does anyone know if you can create your own template in IR edit and import IR codes to your template. I'm trying to create a very univrsal configuration for the major functions that I use for such devices as a DVD/VHS combo.
It would probably take a bit of research but I assume that you could "clone" and existing template and make changes in order to save it as a new template.
Unfortunately, I would suspect that as soon as AMX released a new version of IREdit, they would overwrite your custom modifications.
You could probably assign really high keys to your records and then export your tables to a comma-delimited text file. Delete everything in it except your entries and then you could import the files back into the database after AMX clobbered it.
Danny
Using Access I was able to do the things that I described in my previous reply, but it requires that you go into each of the tables and make entries.
It isn't pretty but it did work. I had wondered if the AMX guys had some kind of program that let them do the dirty work but after looking at the database I'm not so sure. They have a couple of temp tables defined in the database that make it handy to cut, paste, and edit but it is still a lot of work.
Danny
The template system was a good idea, but there are just way too many files out there now that almost entirely ignore it. Rather than edit every one to make it conform to a template, I just do as I have describedl; it's easier, and I don't feel like I am losing anything.
After I started to modify a standard template I noticed problems. I've started to move all the main commands into standard positions like Dave mentioned. Seems the easiest way to go. I ran into problems when I tried to modify a Hitachi DVD/VHS combo and realized that it has discreet (play, stop, pause, etc) commands for the DVD and VHS.
