Best way to map IR functions in NL
Adaptel
I am about to program the AV control portion of my Netlinx system and have what seems to be a REALLY basic, but important, quesion. I have many rooms, with many displays, with many sources in each room. I also have many different panel types (touch, MSPs, IR remotes) to actuate the correct IR functions. My question is, what is the best way to structure a "database" of user-interface device/channels to ir-output device/channels. I want to keep my program easily "modifyable" and structures/arrays of confusing numbers, names, devices, and channels at startup seems archaic. I was wondering if there is some slick way to do this pretty basic function. What is the best way to group all the information elements & reference them? Thanks in advance for any input or insight.
The way it was recommended in class was to have a seperate DEVCHAN array for the buttons, and another for the IR functions, then match them up by the array indices. I always found that far to convoluted to set up and maintain. Sometimes, easy does it best.
Thank you for all your great information. I'm just wondering what the downsides would be to keeping all the button and ir-channel information in a text file or MS database. It could be much easier to modify, but what additional overhead would it add to the system if any?
I guess I'm making this a bigger deal than it really is because in addition to individual room controls & sources, many of my av sources are also modulated into my comcast cable signal onto channels 86-100 and can be accessed from any room. Should I have two seperate variable arrays for each room.....one to track local video output device (volume & source selections on TV or amplifier) and another to select what source is being used & how to activate it? Thanks again.
