Wiring of ICSNet/Video connecter on NXT-CV15 ?
in AMX Hardware
Hi,
As I don't succeed to get video on my NXT-CV15, I suspect something wrong in NXA-AVB. Does someone know if I can connect composite video directly to CAT5 connector on back of Modero ? and if so what is wiring on that connector ?
Vinc
Vinc
see attached diagram from manual
Thanks for picture but I'm confused as Video is indicated as polarity negative ! So where I should connect my two wires of video (signal and ground) on that RJ-45 ??
Vince
video signal (+) = pin 6
video signal (GND) = pin 3
Thanks didn't notice the pin 6
Vince
In fact I try to see video composite coming from a freebox (triple play adsl box used here in france) in PAL Format. If I plug composite video cable coming from freebox to a monitor I get a picture.
If I plug it through AVB or directly on pin 3 and 6 of video connector of modero, I get nothing on Modero. I'm in Video setup page, if I put in auto mode, I get nothing, it keeps unlocked all the time. If I force in PAL it gives also nothing. In Secam I get all the time some lines that scroll through window so I suspect something is wrong in the modero ;(
Vince
