G3 panels buttons
Salut,
I'm just starting a rather large project and am starting to run out of usable space(255 buttons in the channel map). I see that each panel is capable of being 4 devices(?) but I have never used this feature and am not familair with how to set it up and how to active the command, for example button# 200 device 3. Any ideas or help would be appreciated.
Just make sure that inside the setup of the panel you set the panel to use up to 4 devices and if the starting address of the panel is 128, then the rest of the device no. will follow. i.e. 129, 130 & 131. Then inside your coding you will have to define all the 4 devices though they belong to same physical panel. Now you can use 130 which is device 3 in this case to program the button push/release for channel 200. Hope this helps.
cheers,
Zhihao
I played around with your suggestions last week (while soaking up some UV's at the beach) and think I now have a good grasp on the method. As Dave mentioned I often do reuse buttons for many devices that have like transport functions. Mostly I use the 'select/active' method. Merci.
