Data Projector?
Has anyone had any experience with a decent data projector that has (2) HD15 computer inputs, (1) composite, and (1) SVID or RGB input?
I need to provide connections for 2 PCs, one DVD and one VCR. Light output is not a huge deal as I can control the ambient light rather well. I'm projecting to a 5' x 7' screen and I need ceiling mount. RS232 control is prefered.
I am also considering going with a switcher to handle the RGBHV (HD15) and just using one of the Sony projectors that has a single HD15 input and the wireless access depending on the costs.
Any info would be appreciated.
The other I know of would be the Panasonic line; also very bright machines, but with a huge contrast ration. I have one in the shop at the moment, but haven't seen it in use yet because they shipped me an unusable lens. It has up to 3 RGB inputs, but I think to get all three you have to add an input module; likewise for DVI. These are higher end machines, the PT-DW7000 retails for around $25K.
Given the info on the Infocus, it seems that may be the way for us to go since I know the client is trying to keep the budget down.
I usually use an Extron system 8 with every install. Handles most input formats and has audio follow. I had pretty good luck with the Sanyo projectors. The Sony's gave me no problems but the protocol was a pain.
The extra cost for the Extron system 8 is worth it for the flexability it offers. As Thomas mentioned it allows for most formats to be used with one box. What will the client be displaying the most? If video I would suggest a DLP over LCD because of the increased black level with DLP.
Sony have some small bright projectors that allow vga and RGBHV on separate inputs but the auto find command only works on VGA so you have to program the units on RS232 rather than IR
Sanyo support sucks big time and the mute funtion still outputs a lot of light.. if the client can aford barco followed by christie.
Nigel
Recently, we have been selling alot of the Panasonic PT-LB20/30's.
These units work great, have a good picture, and easy control.
These projectors support the same extended 232 commands available on
the larger Panasonic projectors.
A switcher that we have also utilized alot of, the Extron MPS-112.
This unit is 3 (4x1) switchers in one box (VGA,SVIDEO,VIDEO) all with
audio, and program volume control. This unit is in the $550 range.
If you dont require scaling or seamless switching, this unit works great!
