NEC WT600/WT610 Lamp Strike Failure
I have a trio of NEC WT610 projectors intended for a semi-permanent installation, and I need to know a way to reset them if/when they have a lamp-fails-to-strike event. I just had such an event occur on one of those units in my lab, and the only way I had at that time to regain control of the projector was to use the manual power switch.
We've had to service an almost identical install, using the WT600's, with the same problem, twice now.
Has anyone faced anything like this and successfully 1. sensed the condition, and 2. brought the projector back to normal operation via software/serial?
Thanks, all.
Thanks, all.
Thanks, Thomas.
One possibility which I've heard of regarding the projector's action after a strike failure is that it will wait for one entire cooldown period before it will entertain any further control requests.
What I ended up doing was exactly what you suggest: if I get a startup error from the projector I have a relay port on the master pulse a larger relay controlling power to the projector, wait, then restore power, then attempt to strike the lamp again.
