Simple question: how to create multistate button in TPDesign4?
Hello, i'm trying to create multi-state button in TP Designer, but when i try to preview it with G4 Panel Preview, or even download files to panel, nothing happens - i.e. button doesn't change it's state, when i touch it. Can anybody, please, explain me "step-by-step", what should be done to create proper multi-state button (possibly with usage of Animation Wizard - as i did)?
Use the animation wizard, it will walk you thru the steps and worked the first time I tried it. There is also a training video for the TP4 available from the AMX website that is very helpful.
Animation wizard is easy, but one mistake I have made a couple of times is a last state is same as first state - middle states are all correct, just had an extra state at the end from when it was a simple button. If animate time is 1, it is hard to catch right away.
Bill
