DATA via COMM port
Good morning, Masters!
What should be procedure for correct data processing?
I want to analyze string coming from device via COMM port.
If the answer has not come, it is necessary to repeat request or to do something else.
It will be more clear if I give a code.
Notwithstanding what time has expired a body of WAIT is never started so timeOut is FALSE always.
And buffer=='' too. It is independent of the answer comes or not.
PROGRAM_NAME='Main'
dvDEVICE = 5001:1:1;
dvIO = 5001:9:1;
integer timeOut;
char buffer[1024];
CHANNEL_EVENT [dvIO,1]
ON:
timeOut=FALSE;
SEND_STRING dvDEVICE,"$02,'0','7','C','D','F',$03"
WAIT 10
timeOut=TRUE; //There is no answer from device within sec
while (timeOut==FALSE OR LENGTH_STRING(buffer)); // just waiting answer
if (timeOut==TRUE)
SEND_STRING 0,'Communication problem';
else
SEND_STRING 0,"'Got answer =',buffer";
CREATE_BUFFER dvDEVICE,Buffer;
Thanks.. And Sorry for my ugly English as always.
Alex.
    I apologize if I miss something, but it's late and I'm out of caffeinated beverages!
    Ummm, I think what you need to do is something like this:
    PROGRAM_NAME='Main'
    DEFINE_CONSTANT
    INTEGER TIMEOUTTIME = 100  //10th of a second
    CHAR START_OF_RESPONSE[2] =  {$02,'R'}
    CHAR END_OF_RESPONSE[1]   =  {$03}
    dvIO = 5001:9:1;
    integer timeOut;
    char buffer[1024];
    DEFINE_CALL 'SEND DATA'
    		WAIT TIMEOUTTIME 'RESEND DATA' CALL 'SEND DATA'
    	ON:
    			CALL 'SEND DATA'
    DATA_EVENT[dvDEVICE]
    	STRING:
    		STACK_VAR CHAR RESPONSE[50]
    		STACK_VAR INTEGER EXPECTED_RESPONSE
    		WHILE(FIND_STRING(buffer,START_OF_RESPONSE,1) && FIND_STRING(buffer,END_OF_RESPONSE,2))
    		 RESPONSE = REMOVE_STRING(buffer,END_OF_RESPONSE,2)
    		 //HANDLE STRING PROCESSING HERE (Set EXPECTED_RESPONSE to TRUE if response is as expected)
    		 IF(EXPECTED_RESPONSE)            //cancel sending the command again
    		  CANCEL_WAIT 'RESEND DATA'
    		 ELSE                             //reset timer
    I think that will do what you want, but you need to make sure that you set the timeout high enough to make sure you aren't flooding the serial port.
  • Thank Jeff for the answer, it is very useful example and I will try it today.
    Just an informational note; Jeff included it in his code without explanation, but it's important to name your waits when using them in this kind of application. Unnamed waits will stack up if called before the last expired. Named waits will not call a new iteration if the previous has not been canceled or expired.
  • GSLogicGSLogic Posts: 562
    Maybe there's another reason I can't see, but it looks like this code could create a loop if the device "dvDEVICE " went offline or you send a command that will not get a DATA_EVENT response back.
    If "CHANNEL_EVENT [dvIO,1]" triggers the "CALL 'SEND DATA'" and no response is sent from the "dvDEVICE", it would go in to a forever loop.
    I would just resend the "CALL 'SEND DATA'" command only if I get a response from the "dvDEVICE" and I know that it is ready to receive a new command.
        STRING:
                CALL 'SEND DATA'
    Gary,
    I agree. My intentions were to give a starting place, not to write a full comm module for the device. I suppose I really should have included a timeout or in the least coded it to resend the command every 10 seconds for the first 5 attempts, then only resend every minute or two until communication is re-established.
    Alex,
    If you need any help with the timeout portion, just ask and I'll see what I can do. Also, it would be really helpful to know the device you are working with and a few more specifics regarding the communication protocol.
    That is what I thought, I just posted it in case someone tryed your code and wasn't connected to the device.
    Gary
  • Check out tech note 616
    http://www.amx.com/techsupport/PDNTechNote.asp?id=616
    The last example in the tech note is one I highly recommend if the data response packet is a reasonable size.
    Brian
