Modero calibration problem
in AMX Hardware
Hi,
I have noticed the following problem in NXT-1200V panels:
I have made a couple of panel layouts with the panel builder. In these panels there is a navigation bar which has quite small (low height) buttons. The factory set up calibration is not accurate enough and it is pretty hard to hit these buttons in right area. I've have tried to re-calibrate the panel and noticed that the calibration must be made above the two crosshairs, otherwise the panel calibrates erratically and buttons have to be pushed below the right area. I have now made re-calibration so many times that I have learned the right calibration spot - it's about 5 mm above the crosshairs. Problem occurs only in vertical calibration.
I've had this problem with all four 1200V panels I've used so far, so the reason can't be a faulty panel (unless all 1200V panels are faulty when they go out from the stock!)
Has anyone of you had a same problem?
-Kari-
-Kari-
thanks for the reply. I always take care of that I'm looking straight to the screen when making a calibration. I know that the viewing angle may affect a calibration dramatically.
This problem seems to be typical to 1200 panels, as we earlier used a lot of CV12 panels and I never have run into this problem with them (and not with MVPs either).
By the way, I didn't know that calibration is volatile, I have to keep that in mind in the future.
I think the whole idea in that navi bar in that layout is that it takes only a small vertical space on the panel leaving a lot of room for other buttons. Just now I checked the height of these navi buttons, they are 34 pixels high and I think that it should be enough to hit on the right spot.
I can always make bigger buttons but that doesn't change the fact that panels are calibrated incorrectly. If there are two bigger buttons very close to each other it's still possible to hit the wrong spot - this time it only happens to be the other button :-)
I calibrated all panels with a stylus.
Has anyone experienced a problem with modero touchpanels whereby it just loses calibration completely? i.e. it wont respond to any button push (no page flips or anything), yet it is still online? This has happened me 2 or 3 times in the last year or so (most recently with a CV7) and the only way to fix it is to recalibrate the tp. I have no idea why it happens or what causes it. Any ideas?
Shane
It took me awhile but whatever was wrong corrected itself(I hope) or maybe it was the 10 pound sledge hammer.
That being said the couple cases I've had with the panels losing calibration coincided with power outages and involved panels in docking stations so it seems they were probably getting a spike through the docking station. Consequently we're now putting docking station power supplies on UPS's.
It seems you might have a point alexanbo. It turns out one of the devices at the main rack where the NXI is situated was powered off. Hopefully this is more than a coincidence. I will follow this up with the client. Maybe a UPS is what is needed.
Cheers
