Recommended VNC?
                                  in AMX Hardware
                    Greetings,
What would be the recommended VNC program for G4 usage? I have used several with success, but I'm wondering what the official (or unofficial) recommendation is. Hopefully it would be one of the free ones.
Thank you.
Thank you.
I like to use RealVNC. The only issue I've had before - and I don't know if the problem is with the G4 panel or the RealVNC software - was when I was entering text from my keyboard. The panel would get all freaky and sorts when I did that. Such as entering in the protected setup password. Other than that, RealVNC works great - and it's free. It can be used as a client or a server, so you can use it to view your panel from a PC, or for your panel to view your PC.
http://www.realvnc.com/
Joe
by the way Mac OSX now has VNC built in.
i found i could G4 PC control to the Mac fine from a Wireless MVP-8400, but from a hardwired CV7 the refresh rate was dismal, about a frame a minute (both setups were to the same Mac).
not sure why that problem is there, but otherwise the client and i were pleased to see the Mac on a G4.
Curious to learn that VNC is built in in Mac OSX, if so, how do you use it ? as till now I used Chicken of the VNC client to connect to Moderos from my mac computers.
Vinc
Are you saying there's already one there? Perhaps I just need to go into a control panel to turn it on?
That would be slick...
the people who own them have turned it on.
in a control panel somewhere.. called remote access(ish), possibly in a firewall setting somewhere.
check the mac help, i am sure that's where it is described.
