Need some input
jjames
Okay, so I'm programming to parse a response from a LiteTouch Standard CCU. I'm looking for LED status changes. Here's what it's supposed to spit at me:
So here's how I want to parse it:
But it's not working. It seems that the ATOI isn't working. However, if I change the code in the FOR loop to...
Any idea why it won't parse the way I want it to using the ATOI statement?
"'09 XX YYYYYYYYY',13"Where XX is the controls station (00-FF) and each Y corresponds to an LED (1-9) on the control station. If Y = 0 LED is off, else it's on.
STRING: { LOCAL_VAR CHAR REPLY [100] LOCAL_VAR CHAR BUFFER[100] LOCAL_VAR INTEGER STATION LOCAL_VAR CHAR LED_NUM[9] WHILE(FIND_STRING(DATA.TEXT,"$0D",1)) { Reply = "Buffer, REMOVE_STRING (DATA.TEXT,"$0D",1)" IF(LEFT_STRING(REPLY,2) = '09') { SET_LENGTH_STRING(REPLY,LENGTH_STRING(REPLY)-1) REMOVE_STRING(REPLY,'09 ',1) STATION = HEXTOI(REMOVE_STRING(REPLY,' ',1)) FOR(nLOOP_COUNT = 1;nLOOP_COUNT<=9;nLOOP_COUNT++) n_LITE_STATUS[STATION][nLOOP_COUNT] = ATOI(REPLY[nLOOP_COUNT]) } Buffer = "Buffer,DATA.TEXT" } Buffer = '' Replay = '' }
FOR(nLOOP_COUNT = 1;nLOOP_COUNT<=9;nLOOP_COUNT++) n_LITE_STATUS[STATION][nLOOP_COUNT] = REPLY[nLOOP_COUNT]-48... it works just fine, and I get my 0s and 1s I need for button feedback on my panel.
Change:
To:
ATOI(?REPLY[nLOOP_COUNT]?)
Technically, you shouldn?t need the double quotes, however, I was told a while back by an old time AMXer that ATOI doesn?t always work correctly if you don?t include them. So by default I include the double quotes whenever I use ATOI. I had the same problem before with ATOI when I was picking off an element in an array as your example shows and adding the quotes resolved the issue.
Does that do the trick for you?
Worked like a charm. That definately needs to go into the Tips & Tricks section. Thanks for the help!
The ATOI function requires a string parameter. Anything other than a string will cause ATOI to return a 0 (zero).
In your program:
the parameter for the ATOI function is a character, not a string. (Okay, we could start the whole argument that a single character is a string, but according to the Axcess and NetLinx compilers it isn't.) By providing the array index nLOOP_COUNT to the character array (string array) NetLinx provided a single character from that array at that index. To make it a proper string parameter, placing the double quotes around the parameter satisfies the requirement of the ATOI function.
(from a long time AMXer....)
Funny... Never heard of the guy.
