Home AMX Resource Management Suite Software
SVSI Native NetLinx Device Monitor Module
Because "sharing is caring" and currently you can't directly register a native Netlinx SVSi device ...
Should support any encoder or decoder - set up to support more device types if needed
Fully populates info page from device_info. Note that a dynamic virtual device is being referenced as the registering device.
Option to set custom name and description through the proxy command ( eg. send_command vdvRMS,'@-RMS-Asset-Name,')
Metadata:
1. IP Address as hyperlink
2. NetLinx D:P:S
Parameters:
1. Stream #
2. Audio Stream # (Decoders)
3. Host Play
4. Power Consumption
5. Online
Methods:
1. Reboot
2. Stream #
3. Audio Follow Video or Audio Stream # (Decoders)
4. Passthru
  • AntAnt Posts: 54
    Hey Ian,
    Thanks for that - is there a way to query Power Consumption of an SVSi unit?
    Or Fan Speed, Temperature?
    Cheers,
    Anthony
  • Power consumption is set as per the endpoint series
    select
        active(find_string(upper_string(iDevInfo.DEVICE_ID_STRING),'-N24',1)): // POE+ devices
        keyAdd(uKeys, KEY_MAX_POWER, '30');
        active(TRUE):                               // POE devices
        keyAdd(uKeys, KEY_MAX_POWER, '12.5');
    Don't think fan or temperature is in the status query response but there maybe a way through an asynchronous N-act message to get that info - something to look into.
  • @Ant said:
    Hey Ian,
    Cheers,
    Anthony
    Asynchronous updates for both fan speed and temperature can be enabled through the generic events tab on the N-Act programming page of the endpoints.
    The data strings are formatted as shown here:
    temperature = {{temperature}}\r
    fanPercentage = {{fanPercentage}}\r
    I'm sending to a multicast address from the SVSI device with a subscription enabled at NetLinx through the ip_mc_server_open() system function
    At NetLinx data received look something like this (source IP is being prepended onto the amx_log() message)
    (07:43:32.925):: dvIP_NACT_MC -> 169.254.244.47:fanPercentage = 1$0D
    (07:43:35.844):: dvIP_NACT_MC -> 169.254.244.47:temperature = 60.245418$0D
    So yes it is possible to monitor fan speed and temperature in the RMS monitor - just need to add in a data receiver and parse according to the source IP matching the IP address of the device being monitored in that instance of the module.
  • @Ant said:
    Hey Ian,
    Cheers,
    Anthony
    Sidecar module attached here that adds parameters to the above device monitor module.
    Supports temperature, fan speed and bandwidth (encoders).
    Added a custom bargraph for the CPU temperature type with yellow segment 75-95 and red segment 95-100.
    Temperature threshold of 75 is just a W.A.G.
    I do not have exact confirmation for the fan speed units and have not seen any values greater than 5 so again just a W.A.G.
    N-Act file included with module.
    Screenshot of encoder at server attached.
    Multicast Subscriber enabled at NetLinx to receive asynch updates - matches IP and port settings in the N-Act file
    dvIP_NACT       = 0:2:0;
    volatile char sIpAddressNact[] = '239.254.0.1';
    volatile long nIpPortNact = 51004;
    (*                 STARTUP CODE GOES BELOW                 *)
    ip_mc_server_open(dvIP_NACT.PORT, sIpAddressNact, nIpPortNact);
    Mulicast device passed into module as 3rd parameter - this could be tcp server or udp server too as long as N-Act strings maintain formatting.
    (*                MODULE DEFINITIONS GO BELOW              *)
    DEFINE_MODULE
    'RmsSVSiDeviceMonitor' RmsSVSiDeviceMonitor_1(vdvRMS, dvSVSI_DECODER);
    'RmsSVSiNActMonitor' RmsSVSiNActMonitor_1(vdvRMS, dvSVSI_DECODER, dvIP_NACT);
    Registered parameters can be overwritten through the RMS @ Proxy command
    (*                  THE EVENTS GO BELOW                    *)
    data_event[vdvRMS]
      online:
        // DEFAULT KEYLIST = 'temperature|fanPercentage|bandWidthMbs'
        send_command data.device,"'@',RmsDevToString(dvSVSI_DECODER),'-SVSI-NACT-KEYLIST,temperature|fanPercentage'"; // Ignore bandwidth at this decoder - not applicable
