LEVEL_EVENT on 2 Dimensional Array possible?
danportugal
Is this possible? I'm currently getting a syntax error on the LEVEL_EVENT [myArray,1]
Will i need to make this LEVEL_EVENT[myArray[1],1]? Is there a better way?
dvTP1=10001:1:0
dvTP2=10002:1:0
volatile dev myArray[2][3]
volatile integer lvlSlider[2] = {1,2}
volatile integer x
volatile integer port = 0
for(x=1;x<=2;x++)
for(y=1;y<=3;y++)
port++;
myArray[x].number = 33001
myArray[x].port = port
myArray[x].system = 0
REBUILD_EVENT()
stack_var integer tp
stack_var integer dv
tp = get_last(myArray)
dv = get_last(myArray[tp])
send_level dvTP[tp],lvlSlider[dv],level.value
</code>DEFINE_DEVICE
dvTP1=10001:1:0
dvTP2=10002:1:0
volatile integer x
for(x=1;x<=2;x++)
for(y=1;y<=3;y++)
port++;
REBUILD_EVENT()
LEVEL_EVENT[myArray[x],1] is the only option
The device in any _EVENT block can't be an array. You can, however, define more than one _EVENT header for a block of code.
LEVEL_EVENT [myArray[1],1] LEVEL_EVENT [myArray[2],1] LEVEL_EVENT [myArray[3],1] { stack_var integer tp stack_var integer dv tp = get_last(myArray) dv = get_last(myArray[tp]) send_level dvTP[tp],lvlSlider[dv],level.value }Thanks gents.
