ICSNet Hub
in AMX Hardware
Looking at the spec of the ICSNet hub it actually looks to me as if a standard ethernet hub could be used instead. Has anybody tried this?
I think you might need at least a POE switch. I'm not sure but ICS net may use IPX/SPX in lieu of TCP/IP. Again just a guess and would like to know for sure.
An ethernet switch is not compatible with ICSNet in any way.
Don't waste time on this.
Rex
Vinc
The only thing in common with Ethernet is that it uses RJ45 connectors. Like RS485, ICSNet requires termination at the end of runs and has physical limits on the number of devices per run.
Thus, you should never plug it into an Ethernet hub of any kind.
Any thoughts would be appreciated...
It should be possible to use a RJ45-RJ45 Adapter (fully connected) from a computer shop to add an additional patch cable to get the last inches required.......
You have to be careful, there do exist some patch cables constructed so that pins 1 & 3, and 2 & 6 are crossed. Also, there are some patch cables out there that only have 4 wires in them because most 10/100 ethernet only uses 4 wires.
