LG TV discrete tuner commands
Dear All,
I'm trying to control an older model of LG TV ( 55" ) and the only available way is through IR ( no free RS232 ports in my
controller )
The customer has tuned some DTV channels as well some ATV ( for cameras ) and Radio ones.
What I need is to send discrete commands for any band ( DTV/ATV/Radio) but I cannot find any of them.
I'm sending the discrete ANTENNA command, which is working as expected when the TV is on another input like HDMI1, AV2, etc. - it gets the TV out of the external input - but switches it on the last selected tuner source ( DTV/ATV/Radio).
In case the TV has already been switched on a tuner source, the ANTENNA command switches the TV to DTV->ATV->Radio->DTV->ATV->Radio->DTV->ATV->Radio and so on....
I do know that there are discrete RS232 commands for all of the tuner sources. Has anyone of you found the corresponding discrete infrared ones for LG TV's?
George
    Have a look at Global Cache's CONTROL TOWER IR DATABASE. Free. https://irdb.globalcache.com/
    It has what you seek. Almost always does. There may be several code sets for the category - you have to try and see which works on your device.
  • this site is where I first looked on.... it does not have what I seek...
    edited July 2020
    Add an RS232 port at the rack or at the TV. AMX product for serial-via-ethernet:
    https://www.amx.com/en/products/exb-com2
    Or use an old AMX AXB-232++ (ebay at $30, uses AXLINK, 2 data wire and 2 power which can be local to the unit) or a DIGI-ONE SP or LANTRONIC or other IP-to-serial converter ($50 and up, uses Ethernet).
  • [Deleted User][Deleted User] Harman Integrated Technologies Group (ITG) Posts: 0
    Can you use the IR port as 1-way serial?
