SVSI and Dante
Hello I allow myself to post here because I have the following question, have you succeeded in making work on a switch cisco (sg350 ..) on the same vlan the SVSI and the Dante ?? I tried several methods found on the internet but nothing works, each time I no longer have access to my Dante. The solution I found is to make a 2nd Vlan this way it works, but the problem is that I can no longer control the devices on my Vlan Dante (Micro Shure MXA910, ...) will one have a lead ?? Thanks in advance
Answers
  • SVSI and Dante can exist on the same VLAN. The attached document describes connecting BSS and SVSI AES67 audio which is Dante and SVSI on the same VLAN.
  • Hello, thank you for your quick response, if I understand correctly I configure my switch for the svsi (igmp activation, querier, ...) I add the 3 addresses 224.0.0.230/231/232 and I do not configure anything specific for Dante ?? Sorry for these questions
