NI-4100
in AMX Hardware
Hi everyone!!!
I've got the problem with my NI-4100. After my ethernet failed I can't login to NI through http. Also I try to refresh Device tree in NetLinx Studio but programm shows me notification "Authentication Failed For User Name <Blank User Name>".
I can't understand what should I do in this situation.
Please help me!!!!
Please help me!!!!
Have you tried to connect to it via Telnet? Using a PC, hook up a serial cable to the Master's back port. set up a hyperterminal session to it. The baud is usually 38400 out of the box. You can set up security from there.
Is this problem solved please?
The posts you replied to are 14 years old. If you have a similar issue, describe it in detail.
