HOW TO USE DUET MODULES
Hello,
I understand this may be to complicated to explain, but I'm hoping I can get enough information to jog my memory on how to use modules. I have spent countless hours trying to figure out how to talk to them and read past posts about this issue with no luck in helping me understand how to use them. I have completed programer 1 but we did not spend much time on modules.
What I am trying to do is use a NEC module to get things like lamp hours and change the input. When I look at the module it is filled with code to control everything. How do I narrow down just what I need? I don't need all the other processes.
Do I include only the .jar file and then define that module in my main source code?
I am guessing I create a virtual device to send commands to. Virtual devices puzzle me a tad. I certainly understand them more now thanks to this site.
Any help is greatly appreciated
All the interface modules and include files and touch panel files that are included with the module are not necessary to get it to work. But, look that stuff over carefully to see what's going on. In some cases, it will make interfacing with the module much more understandable.
Unfortunately, in all likelihood, you won't be able to get the module to do anything without having a device actually connected. This makes learning how to use the module from the comfort of your remote location difficult.
dvDev = 5001:1:0
vdvDev = 41001:1:0
DEFINE_MODULE 'Cisco_TC_Comm_dr1_0_0' mdlVTC1(vdvDev ,dvDev )//substitute your module here
This is the only code that is 100% required to make the module load to the system. After that you need to read the documentation that comes with the module to get the functions that you want to work to work. Each module comes with a word doc that tell you what all the channels,levels and send commands do.
vdvNECPROJ = 41001:1:0
dvNECPROJ = 5001:1:0
dvTPMAIN = 10001:1:0
BUTTON_EVENT[dvTPMAIN, 1]
SEND COMMAND vdvNECPROJ, "'?LAMP'" // IS THIS WHERE I WOULD SEND THE COMMAND TO THE VD?
AM I ON THE RIGHT TRACK? WOULD I MAKE ALL CALLS TO THE VIRTUAL DEVICE DEFINED IN THE DOCUMENTATION USING THE COMMANDS DEFINED IN THE DOCUMENTATION?
SO THE QUESTION NOW IS HOW DO I USE A VIRTUAL DEVICE?? I KNIDA GET IT, BUT I DONT.
THANK YOU IN ADVANCED!!! YOU GUYS ARE A HUGE HELP... AND SORRY ABOUT ALL CAPS
It souonds to me like yoiu'd really benefit from taking the AMX progrramming classes. Like most things you can kinda learn it on your own but there will always be some gaping holes in your understanding or a lack of knowledge of best practices.
Just contact your dealer rep and they'll get you hooked up. If you don't have a dealr rep then there's something wrong and you should not have gotten hold of the Netlinx software in the first place.
e
On that note, I have figured out the whole virtual device thing and have a good understanding on how that works now that I have played around with it.
I am now trying to solve my lamp hours coming in and storing them in data.text to output to the TP. Any thoughts? when I run diagnostics I can see the lamp hours(in hours) coming back from my virtual device. Everything coming from the actual device is all crazy Hex. I am going to experiment a little bit to see what I can figure out.
Thought??
I wish you the best for programming in the future and hope you get that nasty caps lock habit cured.
alguien tiene el documento de instrucciones del modulo CISCO_TC_COMM_dr1_0_0 por favor
