Digest Access Authentication
Hi, I would like to web scape some data from a web page that uses digest access authentication.
I've captured this from Charles
telnet 192.168.1.11 80
GET /cgi-bin/minerStatus.cgi HTTP/1.1
Authorization: Digest username="root", realm="antMiner Configuration", nonce="e9e1achanged7", uri="/cgi-bin/minerStatus.cgi", response="b47changed342a", qop=auth, nc=00000001, cnonce="a3changed0"
This is nothing like basic authentication, how do I go about implementing this in either AMX or Telnet?
  • piepie Posts: 1
    Howdy,
    am having some difficulty implementing the amx-util-library
    to initiate a GET request to a device (brightSign)
    that requires Digest Authentication
    (just trying to reboot it via an NX-1200)
    have done a lot of digging but am still at a loss.
    below is a rough breakdown of the programming:
    PROGRAM_NAME = “blah”
    include ‘http’
    dvNX1200 = 5001:1:1
    dvIO = 5001:22:1
    dvIPServerTCP = 0:30:1
    dvTstBSign = 0:500:1
    DEFINE_CONSTANT
    username = ‘admin’
    password = ‘admin’
    method = HTTP_METHOD_GET
    requestUri = ‘/action.html?reboot=Reboot’
    char httpResponseBuffer[2048]
    define_function connectTstBSign()
    ip_client_open (500,’192.168.117.199’,80,IP_TCP)
    create_buffer dvIPServerTCP, httpResponseBuffer
    DATA_EVENT [dvNX1200]
    ONLINE:
    IP_SERVER_OPEN(30,81,IP_TCP)
    wait 30 connectTstBSign()
    BUTTON_EVENT[dvIO,1]
    send_string dvTstBSign, httpRequestToString(request);
    DATA_EVENT[dvIPServerTCP]
    STRING:
    stack_var HttpResponse response
        if(httpParseResponse(response,httpResponseBuffer))
            clear_buffer httpResponseBuffer
    DEFINE_PROGRAM
    wait 10 connectTstBSign()
    and then in the http.axi
    per the instructions/example
    near line 955 was added:
    HttpRequest request;
    request.method = HTTP_METHOD_GET
    request.requestUri = ‘/action.html?reboot=Reboot’
    request.version = 1.1
    httpSetHeader(request.headers, HTTP_HEADER_HOST, ‘192.168.117.199’);
    httpSetHeader(request.headers, HTTP_HEADER__FIELD_AUTHORIZATION, httpDigestAuthentication());
    when trying to compile
    a syntax error is thrown at line 957
    as well as a couple of warnings:
    @todo: implement httpParseRequest method
    @todo: implement httpGetHeaderName method
    no idea what am doing wrong
    halp plz!
    cheers,
    pie
  • There is another thread around which I responded to, I was using a Dahua Intercom which needed Digest and I pasted my prog into that
    look at this thread. Hope it helps
    https://proforums.harman.com/amx/discussion/comment/196982#Comment_196982
