enable audit security from telnet?
Greetings,
I'm looking to enable logging to a syslog server audit server, I'm able to set the audit server via telnet without issue but I've found to have the NX controller actually start sending the logs, you need to hit its webpage, go into security and check the box for audit log.
Is there a way to do this through a telnet session or somehow through code without having to hit the controller webpage?
